Toilet Drain/Vent Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2010, 10:46 PM   #1
Toilet Drain/Vent question
Is this an acceptable or functional layout for my toilet drain/vent system.
3 inch pipe goes straight down into san tee laid horizontal
krw73 is offline   Reply With Quote
Old 09-21-2010, 11:38 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 352
Not where I work. Vent needs to be downstream from WC
Old 09-22-2010, 08:00 AM   #3
so is it a code issue or will the toilet just not vent properly? or both? In my plumbing book it has a few different options, which of these two would you recommend?
1. put a wye fitting in the horizontal run (downstream side) of the san tee, venting back from the wye.
2. put a wye or san tee in the vertical drop between the toilet and the bend, venting back from, or would this be putting the vent on the upstream side again?
Can I still put a cleanout in the tee where I have the vertical drop from the toilet going into, using either of these two methods.
Thanks for any and all help
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 11:12 AM
moving toilet. Kaveran Plumbing 1 05-22-2009 08:46 PM
Toilet install - 2 questions BataviaJim Plumbing 11 05-11-2009 02:53 PM
Question about Adding toilet to basement dasaint80 Plumbing 5 05-05-2009 08:27 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
