-   -   Toilet Drain/Vent question (http://www.diychatroom.com/f7/toilet-drain-vent-question-82021/)
krw73 09-21-2010 09:46 PM
Is this an acceptable or functional layout for my toilet drain/vent system.
3 inch pipe goes straight down into san tee laid horizontal
http://i169.photobucket.com/albums/u...18228362_0.jpg
TheEplumber 09-21-2010 10:38 PM
199 Attachment(s)
Not where I work. Vent needs to be downstream from WC
krw73 09-22-2010 07:00 AM
so is it a code issue or will the toilet just not vent properly? or both? In my plumbing book it has a few different options, which of these two would you recommend?
1. put a wye fitting in the horizontal run (downstream side) of the san tee, venting back from the wye.
2. put a wye or san tee in the vertical drop between the toilet and the bend, venting back from, or would this be putting the vent on the upstream side again?
Can I still put a cleanout in the tee where I have the vertical drop from the toilet going into, using either of these two methods.
Thanks for any and all help
