Toilet Drain Is Too Close To The Wall In The Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2010, 07:07 AM   #16
you can use a rear ejecting toilet, also called horizontal ejecting toilet, instead of ejecting out the bottom, they eject out the back, you would probably need to build a decorative box around the pipe coming through the floor, but this would allow you to not break up the concrete.
vtboy51 is offline   Reply With Quote
Basement floor drain causing me anxiety tondar Plumbing 1 06-21-2009 08:06 AM
Can I connect toilet drain to this drain pipe james739 Plumbing 11 04-24-2009 07:06 AM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
