Toilet Drain Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2009, 07:42 AM   #1
Rewards Points: 3,130
All the plumbing layout diagrams I've seen show every toilet drain routed to the horizontal soil stack. Is this absolutely necessary? In the log home I'm building, the drain line at the bottom of the stack will run horizontally across the crawl space and directly under the first floor bathroom. Assuming it will be properly vented, is there any reason I couldn't wye that toilet's drain into the horizontal pipe? Or for that matter, the sink and tub drains as well?
Old 08-03-2009, 09:54 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Assuming its properly vented, that is fine. We do it everyday.
JDC is offline   Reply With Quote
Old 08-04-2009, 07:19 AM   #3
Great, thanks for the info.
Old 08-04-2009, 11:01 PM   #4
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
draining
If it is vented, but dont let the toilet pass by too close or it could suck a trap dry.
lonsplumbing is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 10:12 AM
Can I connect toilet drain to this drain pipe james739 Plumbing 11 04-24-2009 07:06 AM
relocate toilet drain boddah Plumbing 4 01-31-2009 05:21 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
