I have a new house I'm working on and the drain for one toilet is crooked. I have a 4" drain in concrete with a glue in inside closet flange. When I put the closet flange in one side it about 3/4" off the slab, what are my options? I'm hoping they make a flange with more play in it than this one, the other 2 went in and were only about 1/4" off.
There is a 2 pce flange exstention kit I bought at Home Depot for ceramic floors which contains two white pvc rings with foam seals in between. It also has instructions referring to shimming. Hope this helps. SORRY I PITCHED THE PACKAGING
Stan,
A toilet flange should be bolted down on top of the finished floor level with only the thickness of the flange above finished floor level.
The flange and toilet should be as level as possible for the wax ring to seal properly.
The toilet should be leveled with a level across the bowel. There are beveled plastic shims made for the purpose to level the toilet base on an unlevel floor (shim under the rim of the base).
If your flange won't seat better than being 3/4" off on one side, I don't believe that anything short of breaking up the concrete and replumbing it to be level on top of the finished floor is ever going to work properly.
Good luck!
Mike
I'd avoid shimming the flange at all costs. If you have access to the pipe you could add a Fernco hub connector to get just enough flex in the pipe to bolt the flange down. Otherwise a short section needs to be re-plumbed.
Thanks for the replies, I have no access to the pipe to straighten it. The bathroom is in the middle of the house with a concrete slab. The floors are stained concrete so I really hate to bust it out. I think there were some closet flanges with rubber gaskets around them to make the seal, I'm going to go back to the store and look around for anything that may work.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
