Old 02-08-2013, 04:37 PM   #1
Toilet drain "collar" too low?
People,
removed the toilet to put new wax. There was seepage from old one. Noticed the "collar" to which the 2 brasss bolts hook onto is flush with concrete slab. Isnt this too low? The room had thin vinyl tile. Hoping to put nicer ceramic, but that would make the top of the collar too low(?)
Thaks.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 02-08-2013, 04:46 PM   #2
That's why they sell spacers and double thickness wax rings.
noquacks (02-09-2013)
Old 02-08-2013, 04:47 PM   #3
MarginallyQualified
Noticed the "collar" to which the 2 brass bolts hook onto
is flush with concrete slab. Isn't this too low?
Yep. What are you prepared to do to fix it?
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 02-08-2013, 06:04 PM   #4
Install double wax ring OR I believe you can buy a flange adapter at any plumbing store, i.e., HD/Lowes etc., to raise it to the new floor level.
techpappy is offline   Reply With Quote
The Following 2 Users Say Thank You to techpappy For This Useful Post:
noquacks (02-09-2013), oh'mike (02-09-2013)
Old 02-09-2013, 11:06 AM   #5
Flange adapter? Cool! Now this was a post that was very useful, tech. (I knew about thick wax but wanted to address the base collar instead).
Old 02-09-2013, 11:07 AM   #6
with a tile floor, it will be waaaaay too low. Hate to slather a tub of wax just to fill it in. Does this adapter/riser bolt on? PVC cement on? Clamp?
Old 02-09-2013, 11:14 AM   #7
be careful if you use a flange adapter (the type that slides into pipe with rubber seal) for a three inch pipe and it sits on top of tile some toilet horns are bigger and it will sit on flange and toilet will rock
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
Old 02-09-2013, 12:28 PM   #8
Super Moderator
A jumbo wax ring is a safe way to get a good seal---however ,if you want to raise the flange---use one that overlays the old one and screw in----as you were warned in the post above---the 3" push in ones are a problem===
Clog at Toilet Drain Hole Lpitt56 Plumbing 2 12-30-2012 08:46 PM
1.5" vent for toilet with 3" drain? fulmar2 Plumbing 24 11-04-2012 11:06 AM
Upstairs Toilet Drain wab Plumbing 13 06-14-2011 12:15 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
