Old 03-23-2011, 11:03 AM   #1
Toilet Drain
I am remodeling my basement bathroom and had to pour self levelling concrete to level the floor. Now my toilet drain is just flush with the concrete. Will I still be able to install the toilet properly to get a seal or will I need the drain to stick out slightly above the concrete?
gpuetz is offline   Reply With Quote
Old 03-23-2011, 12:31 PM   #2
Toilet Drain
depends on your plans for the finished floor. linoleum you're fine, tile and you'll be going to the store for a spacer or two
the_man is offline   Reply With Quote
Old 03-23-2011, 01:51 PM   #3
Just call me Andrew
Toilet Drain
Flange spacer, they can be stacked:
Andrew
secutanudu is offline   Reply With Quote
How to drain toilet without tank? tripflex Plumbing 8 06-02-2010 09:27 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet bowl won't drain. Sikorsky Plumbing 5 12-31-2009 07:05 AM
shower drain vs tub drain--connected to toilet???? mandalala Plumbing 2 06-24-2009 03:00 PM
toilet drain line rbaggett Plumbing 2 11-28-2008 11:54 AM
