Toilet Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2011, 10:49 PM   #1
toilet drain
Most toilet flanges have a 3" outlet right?My problem is the existing plumbing in the concrete basement floor.The toilet drain in the floor is a aluminum pipe and is all bent out of shape,my flange is too small.I don't know what size the bent oddball pipe is,nothing at the plumbing store matches?HELP!
dawn,s hubby is offline   Reply With Quote
Old 02-15-2011, 06:36 AM   #2
Rewards Points: 1,216
You sure the pipe is the pipe and not a cover that was put over the pipe to keep concrete from going down there when the floor was poured?
COLDIRON is offline   Reply With Quote
Old 02-15-2011, 09:52 AM   #3
I think it,s the toilet drain? I poured water down it,it does'nt backup,no gas smell coming from it.The drains for the sink&shower are ABS 2" pipe,that's why i think this aluminum pipe is for the toilet,it's the only other pipe there!
Old 02-17-2011, 02:10 PM   #4
Owner
LateralConcepts's Avatar
Take a picture if you can. I've never seen aluminum drainage pipe. Also if it was connected to sewer you would definitely smell sewer gases. It should be ABS also.
Sounds more like HVAC duct
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 02-17-2011, 05:07 PM   #5
Possible Radon Remediation pipe that goes under the slab to be piped out side.
Really don't know. Like Lateral said Pictures. I'm sure someone on here will know.
Old 02-18-2011, 10:38 AM   #6
Think your right,we will get a pro to look at it,worst case scenero is we'll have to hammer up the concrete and install proper plumbing.I've never seen a bathroom without a thrown.THANKS GUYS!
Old 02-18-2011, 10:41 AM   #7
Owner
Lots of "pros" here. Can't you post a pic?
Lateral
(208) 818-8241
Old 02-18-2011, 11:00 AM   #8
My best quess is it's 4" lead not aluminum.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 02-18-2011, 04:22 PM   #9
Don't forget to post back and tell us what is was.
Old 02-22-2011, 09:25 PM   #10
I sure will,and thanks again!
toilet drain is too close to the wall in the basement Kirock17 Plumbing 15 02-24-2010 07:07 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Can I connect toilet drain to this drain pipe james739 Plumbing 11 04-24-2009 07:06 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
