Toilet Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2008, 11:56 PM   #1
Rewards Points: 150
toilet drain
i want to add a half bath in particular spot about fifteen feet away from the stack on the first floor. is it ok to have to toilet drain travel this far over to the stack for a tie in?
drewhart is offline   Reply With Quote
Old 11-04-2008, 09:15 AM   #2
This is one of those "check local code" answers. I would think it will be okay but you also need a vent run for that much distance.. Make sure you have proper fall in the line since this is one line you really don't want to clog.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Commerical Building - Install Drain under toilet? TransTech Plumbing 4 02-25-2008 11:08 PM
toilet won't drain scatterbrain General DIY Discussions 14 02-03-2008 01:52 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
