Toilet Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-10-2012, 09:58 AM   #1
Rewards Points: 199
Toilet Drain
Which of these is the best configuration for a toilet drain ?
Going to assume that C is incorrect because of no immediate vent pipe; that leaves A or B.
Which one would be the best configuration ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 10-10-2012, 10:10 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 676
If the "MAIN STACK" is a vent and not a waste stack to an upper floor then I'd guess B
Whats the prize?
Old 10-10-2012, 10:16 AM   #3
Rewards Points: 199
Whats the prize?
Thanks Eplumber,
(No prize ) I was going to go with B at first, but then I thought that A would be more
of a straight shot, however, I still wasn't sure.
What makes B a better choice than A ?
(The main stack is a vent)
Thanks,
Arky
Old 10-10-2012, 10:25 AM   #4
Rewards Points: 13,712
Just missing a trap under the sink in all the pictures.
Old 10-10-2012, 10:35 AM   #5
Rewards Points: 199
?? Not a sink, it's a toilet.
Arky
Old 10-10-2012, 10:49 AM   #6
Plumber
Rewards Points: 676
Originally Posted by Arky217 View Post
Thanks Eplumber,
Thanks,
Arky
This image shows water flow in a sinks trap arm, same applies for toilets. A wye's configuration at it's crotch restricts air movement to the trap.
Old 10-10-2012, 11:32 AM   #7
Rewards Points: 199
Makes sense, thanks.
Arky
Old 10-15-2012, 10:18 PM   #8
Rewards Points: 199
In the following picture, assuming that the 'other drainage' pipe cannot be moved, which would be the better arrangement, A or B ?
Thanks,
Arky
Old 10-15-2012, 10:25 PM   #9
A is the best. this is assuming that the has nothing connected to it other than a lav or nothing at all.
Old 10-15-2012, 10:27 PM   #10
Plumber
Rewards Points: 676
Thanks,
Arky
Are you taking a test or something? I'd hate to give you quiz answers
Old 10-15-2012, 11:02 PM   #11
Rewards Points: 199
No test ; I'm just an old (67) geezer, hoping to get my plumbing right on my retirement house
so when I get to old to move around , hopefully I won't have any plumbing problems to deal with.
Regards,
Arky
Old 10-19-2012, 10:00 PM   #12
Rewards Points: 199
One last time on the toilet drain.
Because of obstructions and space limitations, I need to have the toilet drain into the
stack lower than the tub and sink.
Would there be any potential problems with this arrangement, that is having the sink and tub drain into the stack about a foot above the toilet inlet ?
Thanks,
Arky
Upstairs Toilet Drain wab Plumbing 13 06-13-2011 11:15 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet bowl won't drain. Sikorsky Plumbing 5 12-31-2009 06:05 AM
shower drain vs tub drain--connected to toilet???? mandalala Plumbing 2 06-24-2009 02:00 PM
toilet drain line rbaggett Plumbing 2 11-28-2008 10:54 AM
