Toilet Doesnt Flush Very Strong - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-04-2008, 06:37 PM   #1
Toilet doesnt flush very strong
I have a toilet that when flushed I have to hold the handle down for about 10 seconds to get it to flush with any power. How can I adjust this so it flushes nicely with just one press of the handle?
CocDiezel is offline   Reply With Quote
Old 09-04-2008, 06:42 PM   #2
Send a message via AIM to Marlin
You probably need a new flapper. It's a very difficult job
Marlin is offline   Reply With Quote
Old 09-04-2008, 06:52 PM   #3
Im guessing by the icon, thats sarcasm? Lol.
The flapper is the black rubber thing that seals it right? What should I look for in one or are they all the same? Why would that cause it to flush poorly?
Old 09-05-2008, 12:19 AM   #4
Before replacing the flapper, check the water level in the tank. It should be about 1/2" below the top of the overflow tube. Flush and see if the flapper stays up long enough that almost all the water leaves the tank. If not, adjust the chain so that the flapper "just" seals by removing most of the slack. Try flushing again. Just some things to check.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-05-2008, 10:22 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
if you still have troubles after all of that, we use 'sharky' flappers with the little adjustable float on them. That usually helps the flapper float longer allowing more water to leave the tank.
Journeyman Plumber
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet Flush Handle skittlzski Plumbing 8 02-22-2009 11:29 PM
Back Flush Toilet Randell Tarin Plumbing 1 04-16-2008 07:33 AM
weird pipe noise after toilet flush bourbonboy Plumbing 1 11-30-2007 05:18 PM
New Toilet Does Not Flush klugej Plumbing 3 04-30-2007 11:51 AM
