Old 07-12-2010, 03:56 PM   #1
Toilet doesn't flush good
Have to flush a couple of times or hold the handle down until paper goes down
Jerry K is offline   Reply With Quote
Old 07-12-2010, 04:33 PM   #2
Retired Plumbing Cont.
Could be as simple a fix as a new flapper. Since you have to hold the trip lever down to get enough water for an adequate flush maybe the flapper is worn out.
rockerjockey is offline   Reply With Quote
Old 07-12-2010, 08:20 PM   #3
Look at the chain/strap that connects the handle to the flapper. Take out all the slack you can, and still allow the flapper to seal. What often happens is the flapper doesn't get pulled up high enough and drops before a full flush is accomplished.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Basement Toilet Gurgling zoner2009 Plumbing 4 01-30-2010 12:12 PM
Gurgling sound coming from the base of the toilet YerDugliness Plumbing 1 12-22-2009 09:35 AM
after flush toilet creaking sounds down the piping for about 20 seconds depstein Plumbing 1 05-11-2009 06:39 AM
slow flushing toilet annoyances mcvane Plumbing 12 11-13-2008 04:00 PM
Back Flush Toilet Randell Tarin Plumbing 1 04-16-2008 07:33 AM
