Toilet Doesn't Flush Down Completely - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-22-2009, 07:37 PM   #1
sweaty
Rewards Points: 276
I have a toilet, probably from 1977 when the house was built. When I flush, the tank empties, but the water in the bowl just swirls around. It drains, but the water level doesn't go down as far as it should. Is there an adjustment to the flapper or fill valve, or do I need to replace parts?
sweaty is offline   Reply With Quote
Old 11-23-2009, 07:04 AM   #2
Sounds to me like a build of calcium deposits in the j-bend, and or siphon jet hole. Scrape out what you can see being carefull not to scratch the porcelien. Then soak it in CLR, overnight if you can. That will usually restore normal functioning.
Old 11-23-2009, 07:33 AM   #3
If you know its not clogged, then I would check that syphon hole, if thats what that blowhole in bottom of bowl is called. I've pulled my hair out a couple times trying to get a toilet to flush right only to fine some matter in that hole.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 10:43 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Dual Flush Toilet 2031pratt Plumbing 6 03-11-2009 11:55 PM
Toilet Flush Handle skittlzski Plumbing 8 02-22-2009 10:29 PM
New Toilet Does Not Flush klugej Plumbing 3 04-30-2007 10:51 AM
