A Toilet That Doesn't Clog. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-29-2012, 08:00 PM   #1
Rewards Points: 264
A toilet that doesn't clog.
I have a 4" drain pipe coming from my bathroom. For some reason, my toilet doesn't use 4", it uses like 2, so it's always clogged.
Do they make a toilet with a larger exit hole?
tibberous is offline   Reply With Quote
Old 04-29-2012, 08:05 PM   #2
Rewards Points: 14,278
Not even a camping trailer would have a 2" hole, somethings very wrong.
Any standard toilet is 4".
Is it the toilets hole that's 2" or the flange?
Old 04-29-2012, 08:27 PM   #3
Rewards Points: 150
I think the OP may be looking at the bathrooms sink drain dropping down in to the 4 inch main. Minimum drain pipe size for a water closet is 3 inch drain. The home must have been built by a Exlax salesman.
Jeeps is offline   Reply With Quote
Old 04-29-2012, 08:51 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I think he's talking abou the trapway in the toilet.
Most toilets are 2"
Some are 2-1/8"
If you buy a "Caroma" toilet, they are a washdown toilet and use a 4" "trapway"
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
plummen (04-29-2012), tibberous (04-30-2012)
Old 04-29-2012, 09:46 PM   #5
Rewards Points: 264
Most toilets are 2"
Some are 2-1/8"
If you buy a "C aroma" toilet, they are a washdown toilet and use a 4" "trapway"
Yeah, it's retarded, you use this huge drain pipe, then add this real narrow area for it to get clogged. If it wasn't for all these bull**** "water saving" regulations, I bet they could get a toilet that would flush. "Water-saving", biggest bull**** term they ever got idiots to believe in. Lets 'save' something that can't be destroyed, covers 2/3rd of the ****ing plant, and literally fall from the god-damn sky.
The Following User Says Thank You to tibberous For This Useful Post:
Jeeps (04-30-2012)
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
New toilet causing clog Bigguy0 Plumbing 0 02-05-2010 02:32 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Is this a reoccurring clog in the toilet waste line? darsunt Plumbing 2 06-02-2008 11:11 AM
