Toilet Distance From Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2011, 10:57 PM   #1
Question
Toilet distance from wall?
The plumber left the center of the poty hole less than 12" from the finished wall. Can i install standard size bowl? I thought it should have been more like 15"?
EelectricP is offline   Reply With Quote
Old 09-06-2011, 06:27 AM   #2
12" should be OK with a modern bowl.
Old 09-06-2011, 06:59 AM   #3
DIY staff
Rewards Points: 7,174
Standard is 12 1/2" from the studs to the center of the drain.
Old 09-06-2011, 09:15 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
How much is "less than 12" " ?
Journeyman Plumber
Old 09-07-2011, 08:48 PM   #5
Question
Sorry. I have 11 1/2 so wasn't sure if i could go with standard 12"?
It sounds like i should be ok but didn't know if 12 was minimum.
Old 09-07-2011, 09:32 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 922
Yep, you'll be ok
Old 09-07-2011, 09:43 PM   #7
Doing it myself
Alan's Avatar
Originally Posted by TheEplumber View Post
Yep, you'll be ok
I've had a few toilets where the tank was only about 1/4" from the wall before. Can't remember what type they are offhand, but in most cases, no problem.
Journeyman Plumber
Old 09-07-2011, 10:26 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If worse becomes worst there is always the ten inch model available.
XXX
toilet tank fills even after wall valve shut off msmitymite Plumbing 9 09-11-2016 09:21 AM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
wall mounted residential toilet kr bennett Plumbing 10 12-05-2010 10:03 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
