Toilet Direction Change - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2013, 07:27 PM   #1
Rewards Points: 1,216
Toilet direction change
I want to remove and install it 90deg different from the direction it's in now. Is there a flange or something made I can adapt to do this? the flange is CI and not easy to move. Anybody?
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 07-15-2013, 07:59 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 924
Have you exposed the flange yet?
Some have notches and slots. When the slots are used, the notches might be 90* from there.
The Following User Says Thank You to TheEplumber For This Useful Post:
COLDIRON (07-16-2013)
Old 07-15-2013, 08:06 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,802
I'm not very familiar with CI....
and I can't picture an integral CI toilet flange... which I think you must be refereing.... otherwise, if it is not integral to the CI pipe, just replace it and rotate it.
A picture sure would help
Best
MTN REMODEL LLC is online now   Reply With Quote
Old 07-15-2013, 08:14 PM   #4
Plumber
Rewards Points: 924
You can set toilets in either set of notches--
Might get lucky but won't know until toilet is pulled
Old 07-15-2013, 08:26 PM   #5
Rewards Points: 14,312
The center of the flange need to be 12" from the finished wall, what's it going to be if you turn it?
Old 07-15-2013, 08:33 PM   #6
Not if ya got a 10" toilet... or and 2" offset flange
Old 07-15-2013, 08:34 PM   #7
If you have access under the floor and there's room the cast pipe can be snapped off and turned and recoupled with a hub less connector.
Old 07-17-2013, 03:57 PM   #8
Job done toilet could not be changed, CI flange about 60 years old just 2 small notches on either side. It's Ok.
On-going toilet issue(s) bknifefight Plumbing 4 01-03-2013 12:40 PM
Toilet Flushing Issues Chrishwa Plumbing 3 08-04-2012 12:13 AM
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 09:58 AM
Basement Toilet Gurgling zoner2009 Plumbing 4 01-30-2010 11:12 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
