Toilet Diaphragm Ballcock Need Replaced? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-25-2011, 07:38 AM   #1
Rewards Points: 71
Toilet diaphragm ballcock need replaced?
When the toilet is flushed, it sounds as if the water never fully stops running. I've adjusted the float arm, thus decreasing the amount of water filling the tank (so its not running over the overflow pipe). This didn't stop it.
As I lift on the arm, or as I tighten the screw on the ballcock, the sound I hear goes away. But the minute I release the arm or stop tightening the screw, it starts up again.
All that being said, does it sound as if the ballcock needs replaced? Could it be the flapper? Suggestions?
thaKing is offline   Reply With Quote
Old 10-25-2011, 08:23 AM   #2
Rewards Points: 472
It can't be the flapper doing that. Change the fill valve like this and that will fix the problum
del schisler is offline   Reply With Quote
Old 10-25-2011, 08:31 AM   #3
Rewards Points: 71
Thanks! Will do just that.
Old 10-25-2011, 08:54 AM   #4
Lightfoot's Avatar
Rewards Points: 272
Agreed-fluidmaster is the best (and cheapest) that's rare!
Lightfoot is offline   Reply With Quote
Old 10-25-2011, 09:08 AM   #5
Rewards Points: 71
Best and cheap?! Loving that.
Old 12-13-2011, 12:52 PM   #6
Rewards Points: 71
I'm back. Things came up and I'm just now getting to this (have had the toilet shut off for the past month). So, I purchased the fluidmaster as suggested above. However, I got into my toilet tank and it is a little different - there is no flapper that I can take off, it is part of the overflow tube. Here is a photo of what my tank looks like. http://cdn.handyguyspodcast.com/wp-c...0/toilet_s.jpg
So, how do I go about remove this type of "flapper" so that I can replace the fill valve and flapper from fluidmaster??
Old 12-13-2011, 01:05 PM   #7
Rewards Points: 71
Or should I take this one back and get one that is just the fill valve and bypass the kit that includes the flapper? I'm assuming I can by the fill valve only and not the flapper.
Old 12-13-2011, 01:40 PM   #8
Lightfoot's Avatar
Rewards Points: 272
yes, you can buy just the fill valve without the flapper. Around 10-12 bucks.
Old 12-13-2011, 01:45 PM   #9
Rewards Points: 71
OK, didn't know if I need a new flapper (of flush valve, as I've learned I have) or if the fill valve is all to fix the issue. Thanks!
Old 12-13-2011, 01:54 PM   #10
Lightfoot's Avatar
Rewards Points: 272
Once you change the fill valve and get it adjusted, if it still runs every now and then (without being flushed) then the flapper is leaking and need replaced too, but from your description the fill valve will likely do the trick.
good luck!
Old 12-13-2011, 02:51 PM   #11
if you need the seal for the flush valve and can't find one locally you can get one here:
http://www.mansfieldparts.com/product69.html
Basement Toilet Gurgling zoner2009 Plumbing 4 01-30-2010 11:12 AM
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 08:11 AM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Toilet install - 2 questions BataviaJim Plumbing 11 05-11-2009 01:53 PM
toilet guts need replaced reds_21 Plumbing 5 02-03-2009 08:57 AM
