Toilet Closet Flanger Not Perfectly Levelled - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2013, 07:00 PM   #1
Rewards Points: 85
Toilet closet flanger not perfectly levelled
Hello,
I have just finalized the installation of a new toilet closet flange. The flange is not perfectly levelled. There's a 1/8" difference between the left side and the right side. I know this should be ok with most toilets but do you think it's necessary to try to level it ?
I'm a little bit of a perfectionist so I just wanted to get some feedback.
Photos:
Flange before (old damaged flange that I have replaced - plumber did a bad job at installing the original toilet):
westbank is offline   Reply With Quote
Old 09-08-2013, 07:14 PM   #2
The first thing to do is to get it flush with your finish floor its too high.. The flange should be set to sit on the subfloor and properly fastened using all holes allocated for screws. If your subfloor is level than your flange will most always be level..gl
Also the pex sticking out of the wall doesnt look nice,next time use coppper stubouts as it will give you a more finished look..
Peppe1019 is offline   Reply With Quote
Old 09-08-2013, 07:15 PM   #3
Rewards Points: 320
I agree with you, should be as level/flush as possible. Toilet may rock which is not good. Too much stress on one side. Call him back to install it correctly. Should be able to level/flush it better than that. Now's the time to address it before you go any further.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Peppe1019 (09-08-2013)
Old 09-08-2013, 07:17 PM   #4
Rewards Points: 85
It's flush with the finish floor (the bottom of the flange has to sit on top of the finish floor as per the manufacturer instructions).
Old 09-08-2013, 07:21 PM   #5
I can see in the pics its too high the top of the flange should be flush not the bottom,im a jman plumber have been doing this a long time flanges are always flush to finish floor never had an issue..
The Following User Says Thank You to Peppe1019 For This Useful Post:
jmon (09-08-2013)
Old 09-08-2013, 07:27 PM   #6
Rewards Points: 85
Strange. Always heard the opposite - that it had to be flush with the finish floor
When they installed our American Standard Champion 4, the closet flange was flush with the subfloor. On the first flush, it leaked. The plumber had to put a flange extension and said it was a common mistake to install a closet flange flush with the subfloor.
Old 09-08-2013, 07:42 PM   #7
Rewards Points: 320
The toilet flange itself doesn't have to be perfectly level, but should be flush with finish floor as that's where most of the toilet weight will be. Westbank has a nice graphic explaining it.
Old 09-08-2013, 07:43 PM   #8
Rewards Points: 2,038
Only problem I see with the thing is the all plastic flange. I prefer the Sioux chief with the stainless steel for the t-bolts.
The Following 3 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (09-09-2013), plumberinlaw (09-08-2013), TheEplumber (09-08-2013)
Old 09-08-2013, 07:51 PM   #9
Rewards Points: 85
It's flush with the finish floor on the left side but 1/8" below the finish floor on the right side. The tiler didn't install the tiles close enough so that the flange could sit on it.
Old 09-08-2013, 07:52 PM   #10
Rewards Points: 85
They only sell and install ABS closet flange around here. I would prefer stainless steel over ABS.
Old 09-08-2013, 08:12 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 806
It looks like your flange is set as low as you can get it.
IMO- the flange surface should never be below the finished floor and above is OK.
And you are within the tolerances for being level, remember- this is part of "rough in".
Anchor the flange and set your toilet, sit back and relax.
The Following 5 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (09-09-2013), ddawg16 (09-09-2013), jmon (09-08-2013), oh'mike (09-09-2013), plumberinlaw (09-08-2013)
Old 09-08-2013, 08:32 PM   #12
Rewards Points: 85
Thanks TheEplumber. I will try to keep your quote in mind
Old 09-09-2013, 04:57 PM   #13
Plumber
I would remove the screws and try to shim up the low side.
Then screw it back down.
DidIDoThat is offline   Reply With Quote
Old 09-09-2013, 05:24 PM   #14
JOATMON
ddawg16's Avatar
Rewards Points: 1,964
I wonder how many people have taken the bottome bowl....set it upside down...then take the bare flange and see how it fits to the bottom of the bowl?
If you did....you would quickly see that you have a lot of 'wiggle' room.
ddawg16 is online now   Reply With Quote
Old 09-09-2013, 07:47 PM   #15
If your installing a new toilet you might consider using the waxless fernco.
http://www.amazon.com/Fernco-Inc-FTS.../dp/B000BQUJEA
Tags
closet , flange , level , toilet
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 09:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Rusted-out closet flange found when replacing toilet; what to do? kevind Plumbing 16 09-23-2011 08:00 AM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 08:19 AM
