Toilet Closet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2008, 10:17 PM   #1
Toilet closet flange
I am replacing toilet in 35 year old bathroom. The Toilet closet flange broke and now I need a new one. The old one had a Toilet flange with another tube attached to it. Both the Toilet closet flange and tube fit into the actual drainage pipe.
The drainage pipe in the floor looks black and maybe plastic abs? I went to the Home Depot and got a new toilet closet flange that is white in color and a new lower tube part that is also white in color.
What silicone glue (or PVC Cement) do i use for connecting the closet flange to the tube part? Then when I put them together I just slide into the drainage pipe without using any glue?
kensington is offline   Reply With Quote
Old 04-26-2008, 11:05 PM   #2
They make universal plastic pipe glue that will work on ABS and PVC pipe.
UFoPilot is offline   Reply With Quote
Old 04-26-2008, 11:16 PM   #3
Registered User
Termite's Avatar
Not all plastic pipe glue can be used to attach PVC to ABS. Most glues are for PVC only or for ABS only, but are not approved for both (although it might work ok). There are a couple that are listed to glue PVC to ABS, but generally it is a no-no unless you use the right glue.
Old 04-27-2008, 12:23 AM   #4
If you have abs pipe you need to use an abs flange and abs cement. the glue that they sell for both is not to code.
plumber Jim is offline   Reply With Quote
Old 04-27-2008, 09:06 AM   #5
If the drain pipe is 4" inside diameter, you could try a compression flange.
Ishmael is offline   Reply With Quote
Old 04-27-2008, 09:19 AM   #6
Thanks,
Yes it is 4" diameter.
I was going to put the glued closet flange/tube part into the drainage without any glue but is sounds like I definetely need to have glue in that part also and it should be universal plastic pipe glue?
Rusted-out closet flange found when replacing toilet; what to do? kevind Plumbing 16 09-23-2011 09:00 AM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 12:37 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 10:41 AM
Closet flange unsupported Richo Plumbing 6 01-02-2008 03:44 PM
closet flange wax ring problem elkmo Plumbing 2 01-14-2006 03:30 PM
