Toilet Cleaning - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-30-2010, 12:36 PM   #1
Toilet cleaning
Have older house, need advice cleaning around rim of commode. It is blackened and commode is white. I have scrubbed, and scrubbed. Any ideas as to how to get it white again????
Debbied2u is offline   Reply With Quote
Old 08-30-2010, 12:45 PM   #2
PZ Reject...
works toilet bowl cleaner...are you sure the porcelin hasnt worn off exposing the bare china?
if all else fails replace....
Rambo is offline   Reply With Quote
Old 08-30-2010, 12:51 PM   #3
Thanks, Rambo. Porcelin is not worn off. Is works toilet bowl cleaner the name of the cleaner and where can I get it from?
Old 08-30-2010, 12:54 PM   #4
PZ Reject...
http://www.theworkscleans.com/toiletcleaner.html
Old 08-30-2010, 01:05 PM   #5
Thanks, I'll get some and try it!
Old 08-30-2010, 01:24 PM   #6
Rewards Points: 558
That might be black mold on your rim; if it is then you can try this method for cleaning:
This method will also help to clean your toilet as well as kill black mold in the toilet bowl, pour 1 cup of vinegar in the toilet bowl and 1 cup in the tank with the water. Sprinkle baking soda all around the inside of the toilet bowl and into the water in the bowl as well. This will create some fizzing as the vinegar and baking soda interact. Allow this to stay in the bowl with the lid closed for about an hour.
When you return to the bathroom in about an hour and open the toilet bowl lid, you will see that the mold still appears to be there. Use a toilet bowl brush and scrub the mold stains. Be sure to splash the vinegar water all around the bowl and brush under the rim well with it. Allow the toilet to stay undisturbed for another 15 minutes.
When you return to the bathroom after 15 minutes, flush the toilet and wipe around the seat and rim with a vinegar-soaked cloth. Use the toilet brush to tackle any mold stains that may remain. Remember that you put vinegar in the tank so that when you flushed, it infused the toilet with the mold-killing power of vinegar all over again. Close the toilet lid and leave it for a few hours. Flush it. The toilet will now be mold free. To prevent mold from coming back, simply add 1 cup vinegar to your toilet tank a few times a week this is a cheap and environmentally friendly way to clean your toilet.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
Debbied2u (08-31-2010)
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet tank cleaning dknarnd Plumbing 2 08-10-2009 07:54 AM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
