Old 08-06-2007, 12:26 PM   #1
Toilet cistern problem
Hello
I wonder some one can help me. Recently I noticed a constant stream of water in the toilet pan coming, I suppose, from the cistern through flush pipe, even when the toilet is not flushed, What is causing this? Is it a flap valve failure in the dome? or the leaky ball valve?. There is no water coming from the over-flow pipe.
What can I do to stop this?
many thanks
Pravin
pmasalawala@talk21.com is offline   Reply With Quote
Old 08-06-2007, 09:10 PM   #2
Mechanical Contractor
Change out the flapper.
100% Union and proud of it.
MechanicalDVR is offline   Reply With Quote
Old 08-07-2007, 05:21 AM   #3
Thank you for your reply ,thi is what I thought.
Could you please tell me How do I change the flaapper,please?
Do I need to buy a new dome?
Old 08-07-2007, 05:26 AM   #4
Thank you
Old 08-07-2007, 07:47 AM   #5
RippySkippy's Avatar
...Could you please tell me How do I change the flaapper...
See if this helps.
RippySkippy is offline   Reply With Quote
Old 08-07-2007, 04:38 PM   #6
Wink
Thank you that explains everything
moving basement toilet cibula11 Plumbing 10 10-20-2007 02:22 PM
toilet vent problem? docholaday Plumbing 8 06-21-2007 06:05 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
toilet rough-in problem christinalee Plumbing 1 12-31-2005 06:37 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 09:34 AM
