Toilet The Cause Of Clogging?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-21-2011, 10:54 AM   #1
Rewards Points: 41
Toilet the cause of clogging??
Both toilets in the house have a habit of clogging easily when flushing anything solid.
Plumber said lines were clear and looked good, said the cause was the toilets themselves. Just not enough power in the flush. Is this feasible?
dbower is offline   Reply With Quote
Old 10-21-2011, 11:07 AM   #2
Rewards Points: 1,514
Flush both toilets at the same time (with no solid material inside). If you notice sluggishness not present when flusing just one toilet then you can have a plumbing system vent problem. This in turn can cause clogging within a toilet because the water does not exit fast enough.
The Following User Says Thank You to AllanJ For This Useful Post:
dbower (10-21-2011)
Old 10-21-2011, 11:16 AM   #3
Rewards Points: 41
There is definitely sluggishness in the hall bathroom, just when flushing it alone with no solid material.
Old 10-22-2011, 06:53 AM   #4
Lightfoot's Avatar
Rewards Points: 272
You didn't say how old the toilets are, but are the jet holes (under the rim) flowing freely? If not, you won't get a strong flush. It makes a HUGE difference. Mine got pretty clogged one time, and would just barely flush. I took a coat hanger and cleaned out all the little holes under the rim (and the big one at the bottom), it's been working fine ever since. They do tend to get clogged up with deposits and lime buildup after a while. Worth a shot, and it won't cost you anything but a coat hanger and a few minutes of your time..
Lightfoot is offline   Reply With Quote
Old 10-22-2011, 12:25 PM   #5
Rewards Points: 41
K, thanks I will try that!
Clogging Toilet cmcconville Plumbing 3 08-18-2011 11:36 AM
toilet water inlet kept clogging up handyman.wong Plumbing 7 04-12-2011 08:23 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
How to approach toilet clogging KUIPORNG Plumbing 11 01-31-2007 08:58 AM
