Toilet Bubbling - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2009, 10:09 PM   #1
Toilet bubbling
Whenever the tub gets drained, bubbles come out of the "stem" in the tank of toilet. Why is that?
-J
Jshakour is offline   Reply With Quote
Old 04-15-2009, 05:27 AM   #2
Sounds like you have a clog developing in your main drain line out of the house, possibly roots growing into the line or some sort of debris that has built up. If you are a DIY'r you can buy or rent a "snake" or auger and try to clean out the line from your "cleanout" opening. This clean out is usually located against or near the exterior foundation of your house. Otherwise call your friendly local reliable plumber.
faucetman886 is offline   Reply With Quote
Old 04-15-2009, 06:11 AM   #3
The tub is slow to drain, i will try to unclog the tub and see if the bubbles go away.
Thanks for the help!
-J
Old 04-15-2009, 07:08 AM   #4
Rewards Points: 150
-J
If your toilet bubbles when you drain the tub it is more than likely a main line partial stoppage. My suggestion if you have never run a sewer snake before call a plumber. Those snakes are very powerful and if you get it caught it can cause serious injury. It could also be a vent stoppage which means you might have to go on the roof to clear it depending on the design of your system. If you decide to do this yourself be very careful.
al's sewer is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
bubbling in my toilet...!!!!??? mikebmore Plumbing 3 11-21-2008 05:33 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
bubbling toilet Wahoo Plumbing 5 03-14-2008 05:49 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
