Toilet Bubbles - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-26-2010, 10:22 AM   #1
toilet bubbles
I have a single story home. The master bath toilet bubbles when flushed and fill water to the brim. I am on a septic with drain field…I’ve noticed one of the master bath sinks also runs slow….no other issues…. Toilet is maybe 15 years old. I pumped the tank maybe 18 months ago…..the tank alarms did go off a week ago but has not sounded again……should I start by pumping again or having the main line cleared or? Thanks
jbyron is offline   Reply With Quote
Old 06-26-2010, 12:23 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Does your toilet bubble when you use any other fixtures on the line?
Do you have a bathtub in that room?
Fill up the bathroom sink with water, and then let it out with the faucet still running. Do the same with the tub, and you can even try them both at once for full effectiveness.
If water backs up into the toilet, then you have a clog.
If only air bubbles, it's most likely a venting problem. Air is not being pushed through the toilet vent, but rather up through the toilet when other fixtures are being used.
Journeyman Plumber
Old 06-27-2010, 09:44 AM   #3
Owner
LateralConcepts's Avatar
There's most likely a blockage in the main septic line between the house and the tank.
You mentioned tank alarms. Does everything first run into a sump basin, then get pumped to a drain field?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Large air bubbles in basement toilet Troubled Plumbing 6 02-07-2010 09:11 AM
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 09:11 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
toilet bubbles hexsprite Plumbing 1 11-23-2008 04:36 PM
Air bubbles in toilet thisperson Plumbing 4 12-04-2006 06:44 PM
