Old 12-30-2009, 10:58 PM   #1
Toilet bowl won't drain.
I live in an apartment on the first floor. Recently the toilet got clogged, and since i did not have a plunger i went to get one. Before i left i turned the water off to prevent it from overflowing. My gf forgot the toilet was clogged and proceeded to use it, and try to flush it. Now, after removing the intial clog with the plunger, the bowl does not drain unless i plunge it. The toilet flushed perfectly fine before this happened, any help would be appreciated.
-Ryan
Sikorsky is offline   Reply With Quote
Old 12-30-2009, 11:09 PM   #2
Xtreme DIY'r
I'd say there is still a clog in the pipes
Is the tank filling up with water correctly ?
The water is fully back on ?
Old 12-31-2009, 03:47 AM   #3
Tool Geek
PaliBob's Avatar
You need a new gf.
& Stay Safe
.....Bob Lavery
Old 12-31-2009, 04:28 AM   #4
The tank is filling up, and just to be sure i played with the floater to let more water in the tank and then tried to flush it.
Old 12-31-2009, 05:08 AM   #5
paper hanger and painter
chrisn's Avatar
Originally Posted by PaliBob View Post
You need a new gf.
It is still partially clogged, fill the bowl and plunge some more.
Old 12-31-2009, 07:05 AM   #6
Well i left it alone for a bit, and the problem resolved itself...thanks for the help guys
DIY Tips and Tricks! DangerMouse General Discussion 166 03-18-2012 11:32 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 11:14 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet Bowl Water encouraged Plumbing 2 12-29-2008 10:11 AM
