Old 08-18-2007, 05:45 PM   #1
toilet bowl water level problem?
In this toilet when you flush it the water rises nearly to the top, then goes back to normal. After a couple of hours the water sinks down to where it barely covers the hole at the bottom, as you can see in the picture?
Has anyone experienced this problem? I suspect there is a leak in the pipe at the U bend underneath the toilet, and the toilet valve is too old to respond to this tiny leak. Is this an expensive fix?
darsunt is offline   Reply With Quote
Old 08-19-2007, 10:25 PM   #2
remodeling pro
The water in the bowl should not "leak out" as there is a built in trap in the base of the toilet. I would suspect some sort of venting problem that is creating a negative pressure beyond the toilet and siphoning the water back out. Is this a recent occurance? Has there been any plumbing work done on the house lately?
troubleseeker is offline   Reply With Quote
Old 08-22-2007, 01:05 AM   #3
I do not know how long this problem has existed. There has been much plumbing work done on this house, since it is such an old one. Many drain pipes have been replaced. What type of repair could cause such an odd problem?
I was wondering whether the trap itself could leak?
Perhaps it is not a critical problem, better left alone?
Old 08-26-2007, 02:10 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
Unless the toilet trap itself is cracked or has a factory default allowing it to leak, this is normally caused by a partially clogged vent stack pipe, as troubleseeker advised.
Go up on the roof (carefully) to inspect the vent stack pipe above this toilet. Clean out any birdnest, leaves, debris, etc. that you can reach by hand, and then flush the stack down with a water hose sprayer. If it is badly clogged, you may have to haul a heavy-duty rented plumber's snake up there to snake the stack down from top to bottom first before flushing.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
More On This Topic
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
How to Unclog a Toilet
How to Unclog a Toilet by Expert Village
We have a toilet that's not flushing, or not flushing very well. What we want to find out is, is the problem in the toilet drain, or is the problem in the toilet tank delivering the water to the bowl? So what we do, we have the patented Gilbert's... Read More »
On behalf of Expert Village I'm Nicole from Pet Kingdom and I'm here to tell you about sick snakes. Another problem that often occurs in captive snakes is stomatitas or mouth rot. What that is-is a fungal infection that takes over your snakes mouth and... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
What's coming in older toilets 40 years old and older is lime will buildup in the jet way around the toilet. When the water goes through the flush valve and comes out to the rim, these jets will get clogged with calcium. I am not a proponent of cleaning... Read More »
Low hot water pressure crebive Plumbing 26 01-10-2010 12:54 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
water pressure problem rgmetro Plumbing 6 04-09-2007 04:57 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Water level in toilet bowl Kath Plumbing 10 06-22-2006 04:26 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
