Toilet Bowl Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2012, 09:50 AM   #1
toilet bowl water
My water in my toilet bowl goes right down when I flush,why?
merv is offline   Reply With Quote
Old 12-11-2012, 09:58 AM   #2
Rewards Points: 12,856
Is there water still running into the tank?
Old 12-11-2012, 10:04 AM   #3
Yes,everything is normal except when I flush
Old 12-11-2012, 10:08 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It's supposed to do that?
Journeyman Plumber
Old 12-11-2012, 10:14 AM   #5
I understand the concept,but why is there no water in the bowl left and I have to flush again to restore the water level in the bowl.
Old 12-11-2012, 10:47 AM   #6
there is a little tube inside the tank coming from the ballcock (fill valve) that needs to be in
the overflow tube. that is what refills the bowl after a flush. either yours is not in the right spot or it is clogged at the fill valve.
instead of flushing twice just hold the handle down a little longer so more water goes into the bowl.
make sure the water level in the tank is at the correct height.
Old 12-11-2012, 10:58 AM   #7
Thanks You,much appreciated
Toilet Won't completely flush kmkiley Plumbing 6 07-14-2011 08:05 AM
Water in our toilet bowl sucks out? Bluwolf Plumbing 6 04-23-2011 10:23 PM
No Water entering toilet bowl mjarema414 Plumbing 5 05-03-2009 02:39 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
toilet water nikotromus11 Plumbing 7 03-18-2008 08:47 PM
