Toilet Bowl Setting Compound? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2011, 06:32 PM   #1
Toilet bowl setting compound?
If you use a wax ring do you need toilet bowl setting compound?
djgrant is offline   Reply With Quote
Old 06-06-2011, 06:37 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"Toilet Bowl Setting Compound" ! ! !
What the hell is that?
All that is required is the wax seal, maybe two.
XXX
Old 06-06-2011, 06:43 PM   #3
Ok, I have a "extended" size wax seal and it has the black thing in the middle too. I also have some plastic shims just in case the new tile isn't quite level and I'll put some white silicone tub&tile caulking around afterwards. A contractor told me it would be a good idea to leave a little gab in the caulking at the back of the toilet. If the wax seal ever leaks, stuff will come out the back and you will see it and can then fix it.
Old 06-06-2011, 07:28 PM   #4
DIY staff
Rewards Points: 7,174
Best thing to do is 'dry set ' the toilet without the wax ring---locate your shims,if needed--then remove the toilet--add the wax ring and set the toilet on the shims.
Your contractor is right--caulk only the shims---a properly set toilet should not be caulked to the floor.
Old 06-06-2011, 07:28 PM   #5
just a tool guy
mickey cassiba's Avatar
Methinks some salesman is sellin' ya some bull. One ring, maybe two if the floor is is rough, but the only 'setting compound' I use is settin. my fat arse on the stool, and wigglin' till it touches down.
YMMV(dependin' on yer weight)
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 06-06-2011, 07:55 PM   #6
I just read about it in some online how-to articles. It sounds like something that was used prior to wax rings.
Old 06-06-2011, 08:03 PM   #7
DIY staff
Wax ring or two is it----that's the right way---I know what you are referring to-- I won't mention that method because it only used by people who don't know how to set a toilet.
Old 06-06-2011, 09:56 PM   #8
I like to use my extra pennies to shim it affterwards, that's my 2 cents!!
Otherbill is offline   Reply With Quote
Old 06-07-2011, 06:48 AM   #9
Rewards Points: 1,548
When doing the dry run, be sure the toilet sits firm, without rocking. Suggest glueing any shims onto the floor so they don't move when you do the real installation of the bowl. A few days later, when you are sure it is not leaking, you can caulk around the toilet base so accidental spills in th emidde of the floor don't seep under the toilet and down into the subfloor.
Old 06-07-2011, 12:24 PM   #10
Why not caulk the toilet to the floor? As AllanJ said, shouldn't it be caulked all the way around to protect water from getting in?
Old 06-07-2011, 03:12 PM   #11
See this how-to install toilet link
Notice in step 1 they say "Place the wax seal (with horn) around the discharge and apply plumbers putty around the outside perimeter of the bowl." What is plumber's putty and why is the necessary? or not?
Link about plumber's putty.
My idea had been to put some white silicone tub&tile caulk around the base of the toilet AFTER installation.
Old 06-07-2011, 08:52 PM   #12
DIY staff
I want a leak to show up on the floor--the top of the floor--
If the wax ring fails and the water can not escape and get your socks wet--
It will be week--a month--or years ruining your subfloor before the problem is discovered---It's my way of doing it --that doesn't make it the only way.
Old 06-07-2011, 09:16 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 924
I caulk all the way around the base. But each his own I do know that the UPC states that fixtures shall be caulked
And I have never seen anyone use putty at the base, seems like a waste of time. So is talking about how to caulk a toilet Kind of like the "tape or dope first" on pipe threads debate
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (06-07-2011)
DIY Tips and Tricks! DangerMouse General DIY Discussions 171 09-04-2015 09:50 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Toilet Bowl Water encouraged Plumbing 2 12-29-2008 09:11 AM
Toilet bowl shims rjniles Plumbing 2 08-23-2007 05:06 PM
