Toilet Bowl Rim Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2011, 09:50 AM   #1
Greetings to all! I need some help so here goes. Back in June my water bill spiked to nearly $300.00. Fearing the worst I called a plumber who came out and checked for leaks. He told me my two toilets were the culprit and kept running water so I replaced the guts inside each and voila! July and August went by and the water bill returned to normal. This past weekend the water bill is back up to 300.00. I checked the toilets! My guest toilet is fine but the master bedroom toilet is my issue. Water is leaking from the rim of the toilet bowl into the bowl itself. When I shut the water supply to the toilet off I still get leaking water into the bowl. What gives?! I installed the guts properly. If the water supply is shut off and it still leaks would this add to my water bill? Is the main water supply not shutting off and still feeding water into the bowl? The tank itself does not seem to be losing any water. I will add back in February I had my bathroom floors re tiled and the toilet bowls were removed from the floor and resealed when the job was complete with new wax wings. Any and all help would be greatly appreciated!!!!!!
Msnbcjunkie is offline   Reply With Quote
Old 10-12-2011, 09:54 AM   #2
MikeKy55's Avatar
Rewards Points: 254
It's the flap valve in the tank. It won't appear to be losing water in the tank because it will keep refilling as it leaks into the bowl.
MikeKy55 is offline   Reply With Quote
Old 10-12-2011, 10:04 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
He's right, that's the only way I know of that water can get into the rim of the bowl. Through the flapper. Maybe your flush valve is cracked or damaged. What exactly do you mean by "replaced all the guts" ?? Maybe you left the chain too long on the flapper and it's getting stuck between the flapper and flush valve.
Journeyman Plumber
Old 10-12-2011, 10:09 AM   #4
I replaced the inside guts with a FluidMaster and replaced the flapper a couple months ago. Last night I again replaced jsut the flapper and it's still leaking. I know you said the water will still fill the tank but my question to that is I never hear any running or filling water. That part shuts off completely.
Old 10-12-2011, 10:17 AM   #5
Mark Potter's Avatar
Rewards Points: 150
Can you provide picture of inside the tank?
Mark Potter is online now   Reply With Quote
Old 10-12-2011, 02:20 PM   #6
Rewards Points: 1,446
Use a piece of string or thin wire to hold up the float for the fill valve assembly for an hour. If the tank loses water then there is a leak into the bowl down below, probably the result of the flapper not sealing completely. Check the rim against which the flapper rests for rough spots.
Old 10-12-2011, 02:25 PM   #7
Use a piece of string or thin wire to hold up the float for the fill valve assembly. If the tank loses water then there is a leak into the bowl down below, probably the result of the flapper not sealing completely. Check the rim against which the flapper rests for rough spots.
If you turn off the supply valve below the toilet tank and the flapper is leaking, it will usually be several minutes before the tank empties out and the flow down into the bowl stops.
Old 10-12-2011, 10:50 PM   #8
Rewards Points: 582
you can also put food coloring in the tank to color the water and see if that is what is leaking thru the rim???????
Old 10-13-2011, 02:31 PM   #9
Rewards Points: 150
No one thinks of food coloring for toilets leaks good idea!
DIY Tips and Tricks! DangerMouse General DIY Discussions 171 09-04-2015 10:50 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet Bowl Water encouraged Plumbing 2 12-29-2008 10:11 AM
Toilet bowl shims rjniles Plumbing 2 08-23-2007 06:06 PM
