Toilet Bowl Refill Tube Coming From Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2011, 07:59 PM   #1
Rewards Points: 20
Toilet bowl refill tube coming from wall
Hi, does anyone know why I have what looks like a toilet bowl refill tube coming from the wall (with the water supply line) and into the tank? Once in the tank, it connects to the refill tube that's already there. What is this?
helium44 is offline   Reply With Quote
Old 02-20-2011, 08:03 PM   #2
Originally Posted by helium44 View Post
Hi, does anyone know why I have what looks like a toilet bowl refill tube coming from the wall (with the water supply line) and into the tank, where it connects to the refill tube in the tank and flows into the overflow tube?
Is it to flush a urinal?
Old 02-20-2011, 08:05 PM   #3
Rewards Points: 20
No, it's a regular toilet
Old 02-20-2011, 08:15 PM   #4
is there a floor drain close by? i've seen trap primers connected like that. if there is, have someone flush the toilet while looking in the floor drain... look for a splash of water when its flushed
the_man is offline   Reply With Quote
Old 02-20-2011, 08:36 PM   #5
I would say that you are absolutely correct! I have seen this done from a sink in a laundry, but never from a toilet.
Seems to me like a clever idea!
Old 02-20-2011, 08:51 PM   #6
Rewards Points: 20
Thanks guys. So is the water in this tube flowing into the toilet or away from it?
Old 02-20-2011, 09:17 PM   #7
It flows away from the toilet and replenishes the water in the floor drain trap.
The water needs to be replenished as floor drain traps tend to have the water evaporate, due to lack of use!
Wall mount toilet warnerww Plumbing 3 07-04-2011 08:01 PM
wall mounted residential toilet kr bennett Plumbing 10 12-05-2010 10:03 PM
Saniflo toilet bowl water level vtboy51 Plumbing 2 06-29-2010 08:33 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
