Old 10-28-2010, 02:51 PM   #1
Question
Toilet bowl losing water
I've noticed that the water level in my toilet bowl goes down about 1 inch per day when the toilet is not used. The floor is not wet around the base of the toilet. What could be the cause?
czars is offline   Reply With Quote
Old 10-28-2010, 05:21 PM   #2
One thing I can think of is you might have a venting issue and the water gets partially sucked out of the bowl trap when other fixtures are being used or when a negative pressure situation occurs in the main drain line. The only other thing I can think of is a pet dog likes to drink from the bowl.
The Engineer is offline   Reply With Quote
Old 10-28-2010, 08:56 PM   #3
Homerepairguy's Avatar
You might have a hairline crack between the water trap in the toilet and the drain. One toilet in our home had a hairline crack in the shell which was very difficult to see. There would be water on the floor and I removed and reinstalled the toilet twice thinking the wax ring was leaking. When I finally found the hairline crack it explained everything.
Homerepairguy is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
water on floor around toilet learnin' Plumbing 6 11-16-2008 08:18 AM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
toilet water nikotromus11 Plumbing 7 03-18-2008 08:47 PM
Toilet Flushing ? Piney Plumbing 5 10-20-2007 02:56 PM
