Toilet Bowl Fills, Then Empties - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2016, 05:48 PM   #1
Rewards Points: 338
Toilet bowl fills, then empties
This just started happening today...flush the toilet, the bowl fills up to a proper level. You can faintly hear water leaving, and in less than a minute, the bowl is pretty much empty.
Any ideas? Again, the bowl fills fine, the toilet does not over run its cycle, but the bowl continues to drain out quite quickly after a flush. We are not using it because the water level is just too low. We are on a septic system.
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 01-04-2016, 06:42 PM   #2
Rewards Points: 338
Further testing shows that when I flush the toilet, the bowl overfills, like it might spill out on the floor. Could be a clog, but why is it draining the whole bowl? Floor around the toilet is not wet, no visible water damage below the toilet downstairs.
Old 01-04-2016, 06:45 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,032
Clogged vent causing the bowl to siphon??
Coastal South Carolina
Old 01-04-2016, 07:32 PM   #4
Rewards Points: 582
clogged commode ..or drain line....after it fills up it slowly drains out ...
The Following User Says Thank You to ben's plumbing For This Useful Post:
plumberinlaw (01-04-2016)
Old 01-04-2016, 07:45 PM   #5
Rewards Points: 1,678
Run an auger down the toilet see if it snags something.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
dougp23 (01-05-2016), plumberinlaw (01-04-2016)
Old 01-04-2016, 08:16 PM   #6
Rewards Points: 370
Using a pail / bucket, fill it to the rim then use the plunger. The extra head pressure from being full in conjunction with the plunger often dislodges the blockage. If that fails then go to plan B.
SeniorSitizen is offline   Reply With Quote
Old 01-04-2016, 09:16 PM   #7
Rewards Points: 2,906
I would take a piece of flexible hose and, using a continuous twisting motion, push it into your toilet bowl until the end of it is above the water level in the bowl.
Now, holding onto that hose, flush the toilet. Blow into the hose to clear any water out of it as the toilet tank is filling, and see if the same thing happens. (Blowing into the hose will ensure that the hose is open for air to flow through it, and not so twisted up that air can't flow through it. Also, if the water level is at the height of the toilet bowl, there may not be much air space in the toilet bowl and you may feel like the pressure builds up in the hose as you blow into it, very much like the hose is twisted and therefore blocked off.)
If you have a partially clogged main drain line, then the toilet water could be backing up in the drain piping. As that drain piping gradually empties past the partial clog, a vaccuum develops behind the draining water with the result that it sucks the water out of the toilet bowl. If you're concerned that your hose might not be large enough to allow sufficient air flow to quench the partial vaccuum, blow into that hose. As long as we prevent a partial vaccuum from forming, the water in your toilet bowl should not be sucked out.
By putting a hose into the bowl, air will be sucked through the hose into the drain piping, quenching any partial vaccuum in the drain piping and leaving the toilet bowl level full.
If the hose test confirms that a partial vaccuum in your drain piping is causing the toilet bowl to empty, then the fix is to have the main drain line from your house to your septic tank cleared with a plumber's snake. That drain line gradually gets clogged with solids (mostly from your kitchen sink), and needs to be cleared very 10 years or so to be on the safe side.
Don't figure you can do this yourself with a small hand held snake. The partial clogging from a kitchen sink can go on for many feet. You need to hire a plumber with a motorized snake to clear your drain line all the way to your septic tank.
NOW, I know everyone in here is going to say that the toilet on the second floor of a house is going to empty into the vent stack, and so air coming into the top of that vent stack at the roof should eliminate any partial vaccuum. It could be that the toilet water in this case is backing up pretty much to the same height as the toilet bowl in the vent stack, so that as the water drains away, it could be sucking the water out of the toilet bowl. The hose test will confrim.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
The Following User Says Thank You to Nestor_Kelebay For This Useful Post:
Old 01-05-2016, 10:07 AM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Your problem is typical of a clogged toilet bowl.
You probably have an "item" (I use item loosely) lodged somewhere between the hole in the bottom of your toilet and your drainage piping. When that happens, the "item" acts as a wick and pulls the water out of the bowl.
A good closet auger should release the "item".
Journeyman Plumber
Old 01-05-2016, 02:23 PM   #9
Rewards Points: 338
Thanks everyone! Went to the hardware store and for $15 got an auger. It seemed to help a little, but same behavior. So I went with an old trick, shut off the water, flush the toilet, get as much water out of the bowl as possible. Now pour in half a cup of dish soap and a gallon or two of hot water (not too hot!). And boom....that bowl fully emptied and you could just hear everything was back to good!
Now I gotta tutor my teen on not using half a roll of TP at each sitting...
Thanks again everyone, saved me $100 in a plumber call.
Toilet bowl leaks and rocks--Is flange too high? Daneel Plumbing 5 01-26-2015 11:01 PM
Toilet Bowl Rim Leak Msnbcjunkie Plumbing 8 10-13-2011 02:31 PM
Saniflo toilet bowl water level vtboy51 Plumbing 2 06-29-2010 09:33 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
slow flushing toilet annoyances mcvane Plumbing 12 11-13-2008 04:00 PM
