Old 11-28-2011, 06:36 PM   #1
Toilet Bowl emptying inconsistently
I noticed a pretty intense leak at the base of my toilet yesterday. I removed the toilet to find a wax ring that looked like it was not making contact with the toilet bottom. I replaced it while doubling up the ring to ensure a seal is made between the floor and toilet.
Now I can flush the toilet once successfully, but a second flush just fills the bowl with no water emptying. It then drains slowly over a couple of hours. Sometimes the second flush yields a small air bubble in the bowl.
What in the world am I missing?!?
imnotaplumber is offline   Reply With Quote
Old 11-28-2011, 07:06 PM   #2
Super Moderator
Sounds like you squished the wax ring and it is partially blocking the pipe---
Old 11-28-2011, 07:14 PM   #3
Super Moderator
Or--your pipe was plugged up before the leak---and it's still plugged up----
Old 11-28-2011, 07:41 PM   #4
yes agree with mike seem like a clog thats what caused the seal to leak in the first place...lift commode start dumping 5 gallon buckets... you should see drain back up....if not reset commode making sure bowl wax is straight...
DIY Tips and Tricks! DangerMouse General Discussion 166 03-18-2012 11:32 PM
Toilet Bowl Rim Leak Msnbcjunkie Plumbing 8 10-13-2011 02:31 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet Bowl Water encouraged Plumbing 2 12-29-2008 10:11 AM
