Toilet,bathtub,sewer!?!? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-07-2008, 08:22 PM   #1
my toilet drains in to the bathtub and i cant get the tub to drain at all when i plunge either one it does this in both of the bathrooms....i have a septic tank but we just had it pumped about a year and half ago...so anyone know whats the prob??
thanks leena
LeenaCross is offline   Reply With Quote
Old 04-07-2008, 08:45 PM   #2
Do you have alot of trees around your septic field? Or you could have a pluged vent pipe. I would get the tanked pumped out again. If for the first day or two your drains work normal then stop working you have a pluged field, or you have crushed field pipe. Has anyone drove over your drain field. Pump your tank then go from there.
Good luck
brownie is offline   Reply With Quote
Old 04-07-2008, 09:45 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Have the line to the tank cleaned out 1st, then pump out tank 2nd if needed, sounds like the line is plugged to the tank.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-07-2008, 10:21 PM   #4
Rewards Points: 150
hAVE YOU HAD alot OF RAIN IN YOUR AREA,LIKE SOME PLACES?? if your laterals are standing in water they dont drain well
justdon is offline   Reply With Quote
