-   -   Toilet,bathtub,sewer!?!? (http://www.diychatroom.com/f7/toilet-bathtub-sewer-19624/)
LeenaCross 04-07-2008 07:22 PM
my toilet drains in to the bathtub and i cant get the tub to drain at all when i plunge either one it does this in both of the bathrooms....i have a septic tank but we just had it pumped about a year and half ago...so anyone know whats the prob??
thanks leena
brownie 04-07-2008 07:45 PM
Do you have alot of trees around your septic field? Or you could have a pluged vent pipe. I would get the tanked pumped out again. If for the first day or two your drains work normal then stop working you have a pluged field, or you have crushed field pipe. Has anyone drove over your drain field. Pump your tank then go from there.
Good luck
Ron The Plumber 04-07-2008 08:45 PM
Have the line to the tank cleaned out 1st, then pump out tank 2nd if needed, sounds like the line is plugged to the tank.
justdon 04-07-2008 09:21 PM
hAVE YOU HAD alot OF RAIN IN YOUR AREA,LIKE SOME PLACES?? if your laterals are standing in water they dont drain well
