Toilet Base Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2012, 02:18 PM   #1
toilet base leak
Our toilet is leaking around the base. When I took the lid off the tank, I noticed a white ring floating around loose. Is that what is causing our leak, and how do we fix it?
notsohandyjenn is offline   Reply With Quote
Old 01-28-2012, 02:25 PM   #2
Busy DIYer
picflight's Avatar
Rewards Points: 150
If the leak is from the base around the bowl in the floor, than you are probably looking at a defective wax ring. Did you recently drive a snake down the toilet?
picflight is offline   Reply With Quote
Old 01-28-2012, 07:35 PM   #3
Rewards Points: 582
look and feel the back of the tank to see if it wet....if not then leak is at base as picflight said ..need to remove install new wax ring...
Old 01-29-2012, 01:49 PM   #4
analogmusicman's Avatar
Rewards Points: 560
or,you can do what I did to fix a leak around the base:
let the bathroom warm up nice and toasty (softens the wax),loosen the nuts on the base,"wiggle" the bowl a few times then re-tighten the nuts. (but not too much)
tnx,
analogmusicman is offline   Reply With Quote
Old 01-29-2012, 01:55 PM   #5
Rewards Points: 13,458
Very very bad idea to even try doing it like that.
Uneven heat could crack the base, A leaking ring is about a $3.00 fix to do right, left to leak and it can cost you thousands of dollars to redo the flooring and fix the floor joist.
Old 01-29-2012, 02:51 PM   #6
Rewards Points: 560
joe,do I understand that you're saying that by warming up your bathroom,you can crack the base of your bowl? haven't heard that before!
tnx,
Leak at toilet feed pipe dunixi Plumbing 5 01-28-2012 06:08 PM
Toilet base is surrounded by grout New_2_DIY Plumbing 15 08-24-2011 12:27 PM
Floor damage from a 2nd floor bathroom toilet leak Tamber Plumbing 3 05-02-2011 11:10 PM
Water pooling around the base of the toilet mrsp48 Plumbing 5 06-05-2010 11:16 AM
Toilet problem - Leak in Pipe underneath jackbean Plumbing 7 05-28-2008 10:33 PM
