Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2010, 01:19 PM   #1
toilet
can the toilet paper holder flush down a 50# 7 gal american standard toilet w/o causing problems?
wnpphk is offline   Reply With Quote
Old 07-26-2010, 01:47 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Toilets have built-in traps and I imagine that the toilet paper holder is hung-up inside it just waiting for a bunch of toilet paper, etc. to clog the toilet with.
You need to try to extract it with a crank-handle toilet auger, or else pull the toilet, turn it over and extract it from there.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-26-2010, 01:57 PM   #3
Are you sure its a 7 gallon per flush toilet? If so, that toilet paper roll is probably long gone down the drain. If for some reason its still in the trap, the water from the bowl should soften it up enough to flow past the trap on repeat flushes.
The Engineer is offline   Reply With Quote
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 08:11 AM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
