Old 10-21-2009, 01:17 PM   #1
Default Toilet
My loo flushes great but when I get back from work it looks like it hasnt cleared properly, the water is discoloured, after I flush it looks clean and not a problem, but am wondering if im getting a back lash from the sewer - I live on the ground floor of a block of 6 flats, doesnt smell at all Jilly
JillyMac is offline   Reply With Quote
Old 10-21-2009, 01:56 PM   #2
It is possible that your flush was really not thorough; some of the dirty water did not make it over the hump down inside in back, and over the course of the day impurities diffused and/or migrated through the water still in the toilet bowl and became visible again out front.
In some cases a lump of feces fails to make it over the hump and later in the day it happens to come back into view.
Does this still happen if you waited until the tank refilled, flushed again for good measure, and then left for work?
Bait gone and the mouse trap has not snapped? Maybe ants got there first.
Old 10-21-2009, 03:09 PM   #3
Default Contact the building manager
Your suspicion of the buiding's waste line backing up and spilling into your first-floor toilet is probably correct. I had a hotel room once that had this problem. The convoy of plumbing and sewer cleaning trucks in the driveway of the hotel was a dead give away of the problem source.
Best to get the main sewer line "snaked" now before the back-up spills over onto the floor of your bathroom.
MI-Roger is offline   Reply With Quote
Old 10-22-2009, 05:48 AM   #4
Thanks for your reply I have tried that and hope it works !
Old 10-22-2009, 05:49 AM   #5
Old 10-22-2009, 03:44 PM   #6
Default colored water
both solutions are correct and with most of the low flush toilets the second flush cant hurt
elcheepo is offline   Reply With Quote
More On This Topic
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
If your flapper needs to be replaced, it’s probably the simplest thing you can do. All you’re going to do is flush the toilet, let it run out- turn off the supply line first. Once you’ve drained the tank, you’re going to simply... Read More »
Forcing the trap of the toilet is a great way to empty the toilet completely before you remove it. Forcing the trap is also a good way to unblock the drain. If something gets dropped in the toilet, too much toilet paper gets stuck or something else... Read More »
How to Unclog a Toilet
How to Unclog a Toilet by Expert Village
We have a toilet that's not flushing, or not flushing very well. What we want to find out is, is the problem in the toilet drain, or is the problem in the toilet tank delivering the water to the bowl? So what we do, we have the patented Gilbert's... Read More »
What's coming in older toilets 40 years old and older is lime will buildup in the jet way around the toilet. When the water goes through the flush valve and comes out to the rim, these jets will get clogged with calcium. I am not a proponent of cleaning... Read More »
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 3 09-01-2009 09:04 AM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 12:14 PM
Toilet install - 2 questions BataviaJim Plumbing 11 05-11-2009 03:53 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 4 01-11-2009 01:06 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 08:33 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
