Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2013, 02:41 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 226
Toilet
My toilet is probably 7-9 years old. And I've been noticing that it does not seem to have the flushing power it once had. And gets clogged easily. Is there anything I can do, short of buying a new one??
I have a septic, so harsh chemicals down the drain, isn't good
Barry
Barry J is offline   Reply With Quote
Old 01-20-2013, 02:59 PM   #2
Lightfoot's Avatar
Rewards Points: 272
try cleaning the little jet holes under the rim out with a coat hanger wire. It makes more difference than you'd think, plus it doesn't cost anything (well maybe a coat hanger). Also make sure the hole at the bottom front is not clogged up. Between the jet holes and the hole at the bottom, that is where all the water from the tank comes out of. If either of these is clogged (or partially clogged), the water will flow slower and reduce the amount of force it comes out with.
Lightfoot is offline   Reply With Quote
Old 01-20-2013, 03:26 PM   #3
Rewards Points: 4,780
Getting clogged might or might not have anything to do with the toilet. Theoretically, nothing should have happened to your toilet to change that. If it clogs, it's probably because something down your drain line is partially clogged. That could also affect the "flushing power". I'd address that first. As long as the tank fills up (look inside to check), and the water goes into the toilet when you flush, there's nothing much more the toilet itself can do.
jeffnc is offline   Reply With Quote
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 10:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
