Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2013, 04:01 AM   #1
beginner50's Avatar
Toilet
Just bought this house a few months ago and my upstairs bathroom toilet smells terrible!!! I can flush it and it goes away for a bit but comes basically right back??? I have no plumbing experience and have no idea what it might be!! Also it feels like it is leaning forward!!! HELP its disgusting!!
beginner50 is offline   Reply With Quote
Old 01-18-2013, 05:08 AM   #2
DIY staff
Rewards Points: 7,174
You have a bad wax ring under that toilet----
The solution is to remove the toilet---clean up the floor --make sure the flange is in good shape--then reinstall the toilet with a proper wax ring and new bolts.
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (01-18-2013), jagans (01-18-2013), Lightfoot (01-18-2013)
Old 01-18-2013, 10:21 AM   #3
beginner50's Avatar
Will that fix the smell?? I can't imagine a wax ring being to expensive.
Old 01-18-2013, 10:29 AM   #4
Rewards Points: 13,300
Less then $5.00.
The toilet leaning foward might not be a good thing, often time when someone puts of doing the DIY 101 job of replacing the ring water will have rotted out the subflooring to the point it needs replacing.
Never know what your going to find when you remove a toilet, broken flange, no flange, rotted subflooring, rotted floor joist, rusted out cast iron pipes.
Old 01-18-2013, 10:47 AM   #5
Roofmaster
Rewards Points: 2,172
How old is the house?
How old is the toilet?
Tips:
Shut off the water, flush the toilet. shop vac (Take the filter out!) the remaining water in the tank. undo the supply nut. Old? 5/8" New? Channel Locks. It is much easier to first remove the tank from the base, than to remove the whole toilet as a unit IMO. (Ill get some grief on this one, but that's what I always do nowadays )You will then have to replace the tank to bowl gasket, and the bolts and washers, but it is worth it to me at 66 with a bad back. Your mileage may vary. If the heads on the tank bolts are messed up, you may want to forget this, but if the head is messed up, the bolts aren't long for this world IMO. You need a large Flat tip to hold the head, and a deep well socket extension and ratchet to get to the nuts underneath. I think they are 9/16" (14MM) Not sure.
It sounds like you are new to this. Hopefully you have some decent tools. Removing the hold down bolts can be a sticky wicket, depending on the type of flange you have. Yours might be broken if your toilet is rocking. If that's the case you will need to cut the bolts off below the nuts. Close Quarters Hack Saw (Tough) Sawsall with hack blade (Medium) Right angle grinder with thin reinforced metal cut off blade, Cake. (Wear Face Schield, leather gloves, and ear protection)
Take off the caps and get back to us with pictures.
Old 01-18-2013, 10:49 AM   #6
beginner50's Avatar
House was built in 1915 and I think the guy who owned it before short cut everything!! I have no clue about how old the toilet is!!
Old 01-18-2013, 01:14 PM   #7
Roofmaster
Pictures please, wide and close. Not too many short cutters in 1915. Dough Boys, You may be in for a good one. Probably a wiped joint on the closet bend.
:w histling2:
Old 01-18-2013, 01:39 PM   #8
Rewards Points: 712
With the toilet leaning my money is on a rotted floor or the flange too tall . I recommend getting a plumber to do this one and pay a little XTRA to watch so you can learn . Sewer gas in your house is nothing to take lightly .
SeniorSitizen is offline   Reply With Quote
Old 01-18-2013, 02:01 PM   #9
Roofmaster
Not sure what you know, or even if you have a second bathroom to use, but Fairview may be right, up to a point. If the floor is rotten, which it probably is, The toilet has to come off, the old floor has to be cut out where damaged up to the joists, nailers have to be added to the joists, and blocking to the floor, and the floor replaced with minimum 3/4 inch plywood. We are talking about carpentry work, and I would do what I could to make the job easier for the plumber. The toilet HAS to come off, so I would accomplish this task first. It sounds like you may have an old toilet that should be replaced, but we don't know that, as you have posted no pictures.
The only toilet I have used in the last several years is the Kohler Wellworth, and they have given me no trouble at all, but there are other good ones available.
Once you get that toilet off and stick a big rag in it, and we can see the floor, maybe we can help. We cant now.
If you are the squemish type, and well off, just call a plumber. Some people cant even stomach the sight of the old wax.
Changing my Kids Diapers never bothered me, the way I see it is S**T is just another part of life. Gross but true.
Just figured Id let you know what you are in for so you dont bite off more than you can chew
Old 01-18-2013, 02:16 PM   #10
beginner50's Avatar
Well the guy I got it from was renting it out, so it wasn't a shortcut in the 1915' s but I will post pics to show what I mean.
Old 01-18-2013, 02:19 PM   #11
beginner50's Avatar
Yeah I'm very new to this stuff but want to learn. I'm not well off and I got kids and **** doesn't bother me!! I am going to replace the floors anyway but I do have a 2nd bathroom so I can do what I can with this one!! I will send pics soon!!
The Following User Says Thank You to beginner50 For This Useful Post:
jagans (01-18-2013)
Old 01-18-2013, 04:37 PM   #12
DIY staff
Changing a wax ring and even fixing a bad flange is not all that difficult --pull that stinker and tell us what you find---
Old 01-19-2013, 10:06 AM   #13
Roofmaster
Wheres the pictures? Still in the dark room?
Old 01-19-2013, 10:19 AM   #14
Also if your flushing and and the waters coming back into the bowl then you have one of several things going on that will need to be addressed.
Lines plugged up, vents plugged up, septic tanks full if you have one,there's something wrong in the distrabution box, or the leach field has failed.
Old 01-19-2013, 10:21 AM   #15
beginner50's Avatar
I've just got so many projects going with this house. I've got the kitchen I'm painting and stripping down cabinets to stain I haven't had time to get up there and get it checked out!
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 02:39 PM
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 10:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
