Old 09-28-2008, 02:21 PM   #1
Question
Toiler Shut Off Valve
water contues to run in toilet even though shut off valve is off?/ replaced the Fludmaster Fill valve which was leaking but wonder if the shut off valve needs to be replaced and how difficult is that?
DChomie is offline   Reply With Quote
Old 09-28-2008, 03:42 PM   #2
Your question is confusing. How did you replace the fill-valve if the shut-off valve doesn't shut the water off? The fill-valve, if adjusted properly, will stop water from entering the tank, even with the water supply valve turned on.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-28-2008, 04:08 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
He most likley shut the water main.
Old 09-28-2008, 05:25 PM   #4
What can I find here?
Winchester's Avatar
Depends on your setup. I just did this the other week with our toilet downstairs. New wax ring, bolts, stainless supply line, and 1/4 turn shutoff valve.
Now for mine, I simply had to remove the nut behind the shutoff valve and replace with the new shutoff valve.
I would hope yours is done similarly. The plumber was thinking ahead if it's just soddered.
Winchester is offline   Reply With Quote
Old 09-28-2008, 11:13 PM   #5
Electrician
SD515's Avatar
I'm wondering if the OP is refering to the flush valve/flapper.
Kyle
shut off valve under sink mathmama Plumbing 7 05-16-2010 06:27 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 01:44 PM
Sloan flushometer valve won't shut off BradG Plumbing 3 01-24-2008 10:04 AM
Water Valve won't shut off armywife Plumbing 1 12-17-2007 06:16 AM
