-   -   Toiler Shut Off Valve (http://www.diychatroom.com/f7/toiler-shut-off-valve-27486/)
DChomie 09-28-2008 01:21 PM
water contues to run in toilet even though shut off valve is off?/ replaced the Fludmaster Fill valve which was leaking but wonder if the shut off valve needs to be replaced and how difficult is that?
majakdragon 09-28-2008 02:42 PM
Your question is confusing. How did you replace the fill-valve if the shut-off valve doesn't shut the water off? The fill-valve, if adjusted properly, will stop water from entering the tank, even with the water supply valve turned on.
buletbob 09-28-2008 03:08 PM
He most likley shut the water main.
Winchester 09-28-2008 04:25 PM
Depends on your setup. I just did this the other week with our toilet downstairs. New wax ring, bolts, stainless supply line, and 1/4 turn shutoff valve.
Now for mine, I simply had to remove the nut behind the shutoff valve and replace with the new shutoff valve.
I would hope yours is done similarly. The plumber was thinking ahead if it's just soddered.
SD515 09-28-2008 10:13 PM
I'm wondering if the OP is refering to the flush valve/flapper.
