Tips On Soldering Slip Joint On Vertical Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2012, 02:47 PM   #1
Rewards Points: 682
Tips on soldering slip joint on vertical pipe?
I recently soldered a slip joint on a drainage pipe for a p/t valve on a water heater. I pushed the slip joint up from below. When I soldered the bottom of the slip joint first I had a hard time getting the solder to draw in because I think the slip joint squeegeed the flux upward.
Any tips on how to do this better in case I do this with pipe with water pressure? I've seen a plumber do this when replacing one of our outside shutoff valves, I remembered he worked pretty fast.
darsunt is offline   Reply With Quote
Old 04-06-2012, 02:48 PM   #2
Rewards Points: 682
Here is a diagram of what I did
Old 04-06-2012, 03:26 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 682
I doubt the flux was an issue unless you wiped it off with your hand.
Most people use too much flux- it only takes a film layer. Probably not enough heat on the fitting
When soldering vertical, I heat and solder the top half first. Then a little heat at the bottom cup. Touch the solder to it and it will suck in by capillary action- solder is pulled to the heat. It also follows flux- like the ugly runs down a vertical pipe
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (04-06-2012)
Drain pipe leak, quick fix? Ultrarunner2017 Plumbing 15 02-15-2012 08:57 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Soldering copper pipe gail synsteby Plumbing 14 03-22-2008 12:08 PM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 09:54 PM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 12:29 PM
