-   -   Tips on soldering slip joint on vertical pipe? (http://www.diychatroom.com/f7/tips-soldering-slip-joint-vertical-pipe-139449/)
darsunt 04-06-2012 02:47 PM
I recently soldered a slip joint on a drainage pipe for a p/t valve on a water heater. I pushed the slip joint up from below. When I soldered the bottom of the slip joint first I had a hard time getting the solder to draw in because I think the slip joint squeegeed the flux upward.
Any tips on how to do this better in case I do this with pipe with water pressure? I've seen a plumber do this when replacing one of our outside shutoff valves, I remembered he worked pretty fast.
darsunt 04-06-2012 02:48 PM
1 Attachment(s)
Here is a diagram of what I did
TheEplumber 04-06-2012 03:26 PM
199 Attachment(s)
I doubt the flux was an issue unless you wiped it off with your hand.
Most people use too much flux- it only takes a film layer. Probably not enough heat on the fitting
When soldering vertical, I heat and solder the top half first. Then a little heat at the bottom cup. Touch the solder to it and it will suck in by capillary action- solder is pulled to the heat. It also follows flux- like the ugly runs down a vertical pipe :whistling2:
