Tips For Removing A Tub Drain Plug - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-29-2010, 04:26 PM   #1
Angry
Tips for removing a tub drain plug
This is probably a delta. It is what I would call a manual plug... that is if you want the tub to fill, you push down the plug, when you want it to drain you pull it up. It isn't part of the overflow.
This one has a removal knob on top, but once we get that off, we can't get the rest of the stopper/plug thing out.
The tub barely drains right now. We've run a drain auger down the overflow - got about 4' in there, and didn't encounter any gunk. Seemed to get stuck a couple times, but figured it was bends in the pipe. So now we figure the clog is right at the drain, but we can't get the stopper out..
Any suggestions?
LLB419 is offline   Reply With Quote
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 10:49 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
