Tip For Scratched Toilet From Snaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2014, 07:27 AM   #1
Rewards Points: 2,516
Tip for scratched toilet from snaking
Scratched the hell out of my toilet the other day when unclogging it. Tried using Softscrub but it didn't do much. Got a tip to use Bar Keepers Friend cleanser with a Scotchbrite pad. Well the results speak for themselves.
hammerlane is offline   Reply With Quote
Old 11-08-2014, 07:28 AM   #2
Here is the before photo
Old 11-08-2014, 07:42 AM   #3
Rewards Points: 13,712
#1 Should have been using a closet auger if the clog was in the toilet it self not a snake.
Remove the toilet if snaking the drain line.
A Prumus stone is what I would have used.
jmon (11-08-2014)
Old 11-08-2014, 08:08 AM   #4
Rewards Points: 12
JoeCaption is right.
But on the bright side, its already scuffed up for some paint...If you could live with that.
BrtG is offline   Reply With Quote
Old 11-08-2014, 08:08 AM   #5
Rewards Points: 282
Agree with Joe, but what's done is done. You just want it to look better at this point.
I really don't know how to get those scratches out. You may have to pull the toilet to paint the porcelien to make it look half way decent again. Idk.
At that point, may as well replace it. Too bad, it looks like a fairly new one. Luckily they're not that expensive.
Stay tuned, others may have more suggestions/ideas on what you can do to make it look better.
jmon is offline   Reply With Quote
Old 11-08-2014, 08:39 AM   #6
I think you two may have misunderstood. I did get the scratches out by using the Bar Keepers Friend and a Scotchbrite pad. Maybe I should of labeled the photos.
Tip for scratched toilet from snaking-before1.jpg   Tip for scratched toilet from snaking-after.jpg
Old 11-08-2014, 08:58 AM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 676
LOL -I understood, but perhaps that was because I have a bottle of Barkeeper.
Thanks for sharing
Old 11-08-2014, 09:01 AM   #8
Thanks for sharing
Yeah I was surprised with how quick & easy they came out with the Bar Keepers. Next time I'll wait and borrow my buddy's closet auger when plunging doesnt work.
Old 11-08-2014, 09:18 AM   #9
Rewards Points: 1,250
If the surface is truly ceramic that is only surface discoloration because ceramic has been used to machine steel for several decades.
SeniorSitizen is offline   Reply With Quote
Old 11-08-2014, 09:46 AM   #10
Plumber
Rewards Points: 676
A closet auger will leave marks too- just not as bad.
An old rubber floor mat laid in the toilet will help
Old 11-08-2014, 10:20 AM   #11
Rewards Points: 282
Sorry hamerlane, totally misunderstood your post. Luckily eplumber knew what you were talking about.
Old 11-08-2014, 09:28 PM   #12
Rewards Points: 139
Very nice. I use BarKeepers Friend too (or Bon Ami) for metal marks on toilets and bathroom sinks. They also work well on my stainless steel pots and pans, window fans, stand fans, air conditioner, etc.
Druidia is offline   Reply With Quote
Old 11-09-2014, 12:25 AM   #13
Master Plumber
Javiles's Avatar
Rewards Points: 996
Old problem, they come right off with everything a plumber has on their truck emery cloth, plumber roll mesh or standard while the toilet has water in it just buff away, the scuffs come right off,
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
toilet leak issue: need advice michaelw Plumbing 5 07-01-2015 08:18 PM
toilet paper holder boilermaker27 Plumbing 2 09-13-2013 06:10 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
