Tiolet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2011, 08:09 AM   #1
tiolet flange
tiolet flange too close to bathtub what do i do
crock is offline   Reply With Quote
Old 04-30-2011, 08:13 AM   #2
NACE Coating Inspector
mustangmike3789's Avatar
wood floor or concrete?
mustangmike3789 is offline   Reply With Quote
Old 04-30-2011, 08:20 AM   #3
tiolet flange
concrete thanks
Old 04-30-2011, 08:25 AM   #4
Plumb or Die!
How much too close? An offset floor flange would get you 1 1/2".
plumber666 is offline   Reply With Quote
Old 04-30-2011, 08:26 AM   #5
if you only need a couple of inches you can use an offset flange with very little concrete demo. if it needs to go farther, then you will have to cut a trench in the slab and go from there
Old 04-30-2011, 04:21 PM   #6
Veteran Rehabber
I had a similar problem and learned that not all toilets are the same width. Fortunately I was replacing the toilet and was not concerned with keeping the old one. You might be able to save 1 1/2" with a smaller (less wide tank) toilet.
CMHbob
Visit my blog for latest project and reno tips!
CMHbob is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
Closet flange too high dank Plumbing 8 04-14-2010 01:23 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 08:22 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
