Time To Replace Hot Water Tank - Options - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-25-2013, 07:13 PM   #1
Time to replace hot water tank - options
My home has a hot water tank. It is connected to my home heating furnace/boiler (oil). Since the tank has been corroding and showing signs of leaking, my plumber suggested I replace it.
He said my options are
- replace the hot water tank
- get an electric water heater
- run the water through my existing furnace/boiler
He says that running the water through my furnace is the common way to do it. He seemed a little surprised that I even had a hot water tank.
Do any of you have any suggestions? How do I make the decision. The most expensive option seems to be replacing the hot water tank with a new one.
Thanks in advance.
Norm
eastcan is offline   Reply With Quote
Old 09-25-2013, 07:46 PM   #2
Rewards Points: 1,700
Option 3 still requires a tank and a heat exchanger. SO go with option 1 and call a different plumber.
Old 09-26-2013, 07:32 AM   #3
Rewards Points: 1,214
If I understand you your hot water comes from your heater which is called a summer winter hookup.
I would just install an electric water heater and cap off the domestic lines at the heater.
Depending where you live you usually can shut off your main heater several months a year saving mucho oil.
Always get several quotes before a major expenditure.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 07:03 PM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 08:37 AM
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 07:43 AM
installed new hot water tank and now we only get hot water if 2 sinks on at same time Terryh Plumbing 5 07-26-2010 04:54 PM
