Tiles On The Top Of Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2010, 03:25 PM   #1
Rewards Points: 115
Tiles on the top of tub
The first row of tiles around the top of my tub have become lose, 3 of them have totally come off. I did notice the board in back of them is worn from water damage.
What would be the correct process to fix this?
I was just going to recork them.
Carloscda is offline   Reply With Quote
Old 01-17-2010, 04:02 PM   #2
sounds like water damage and you may want to look into replacing when you can, if not now you most likely will have to later. this sounds like the tip of the iceberg
Old 01-17-2010, 04:34 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow, it's all over for that tub surround. More than likely the tile was installed over drywall and drywall won't last forever. Sounds like all the bottom row or two or three rows should be removed and new wallboard installed in that area. Use cement board this time.
XXX
Old 01-17-2010, 07:07 PM   #4
Rewards Points: 115
Thanks for the reply's, It's been on there for yrs and I'm thinking regular drywall was used?!
I'll take out the 2 rows and see what it looks like & take it from there.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 06:29 AM
How to cut 16 x 32 Floor Tiles & Trowel size to use atm Tiling, ceramics, marble 3 09-08-2009 07:48 PM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
