Old 11-13-2008, 02:25 PM   #1
tile and toilet flange question
I am building a cabin and I am about to install ceramic tile in the bathroom. The floor is 3/4" o.s.b. with hardy backer board over that. From what I have read on this forum the toilet flange will sit on top of the tile after tile is installed. My question is do I just need to cut a whole in the tile large enough for the P.V.C. sewer drain pipe or will it need to be as large as the flange so the top of the flange is level with the tile. How is the flange held in place after it is installed with tile.
rbaggett is offline   Reply With Quote
Old 11-13-2008, 04:31 PM   #2
The top of the flange can sit level with the new tile or the flange can sit on top of it. There should be holes around the outside of the flange (4 of them) that get screws installed into to hold the flange to the floor. If you do not secure the flange, and the toilet wiggles, it could break the flange or the piping under it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-13-2008, 05:43 PM   #3
bradnailer's Avatar
What he said but I'd add to use brass screws.
If you install the closet flange on top of the tile, you will need to drill holes through the tile to secure the flange.
bradnailer is offline   Reply With Quote
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 12:37 PM
Toilet Headaches, please help! slatergrl Plumbing 8 02-18-2008 07:07 AM
Toilet Flange txbostont Plumbing 5 10-31-2007 12:01 PM
toilet install over new tile floor dbrew Plumbing 6 02-21-2007 12:17 PM
Adding toilet in basement with tile on the floor Kyle Plumbing 6 09-13-2006 09:59 PM
